Lifter Noise on zr2 blazer, looking to buy. Opinions Please!!!!
Old Jun 5, 2009 | 05:26 PM
michigan_engineering's Avatar
michigan_engineering is on a distinguished road
Question Lifter Noise on zr2 blazer, looking to buy. Opinions Please!!!!
I currently own a '98 LS 4 dr 4x4 blazer, 172K miles, and found a 99 zr2 for $2700. Everything is great cosmetically, through and through, but upon test driving I hear a pretty loud tick tick noise (probably a lifter?) that seems to quite down after warm up. The zr2 has 150K miles. Should I buy it???? Is this a big issue to fix or???? Additionally, the oil cap is missing, which makes me curious. Otherwise, the truck is meticulously clean.
Old Jun 5, 2009 | 08:21 PM
AJBert's Avatar
Lifters seldom fail on the 4.3L. I'd tell them to fix the noise first, then buy it. Otherwise, you may end up spending more to fix the problem than what you paid for the truck. I'm thinking something in the lower end is going rather than a lifter.
Old Jun 5, 2009 | 08:24 PM
Really? Gauging by the numerous posts on here of "lifter" noises I thought thats what it may be, but the lower end is definatly a possibility
Old Jun 5, 2009 | 08:29 PM
There is the possibility for a wiped cam lobe. I have seen this before along with a stuck lifter. It really depends on how well the motor was serviced by the previous owners.
Old Jun 5, 2009 | 08:34 PM
Yea, I agree. I think i'm going to buy it anyways. Everything on it is mint, except for the engine. Even if it does fail, it would make a great engineering project.... hehe maybe ls2? ls7??? haha
Old Jun 8, 2009 | 09:41 AM
jstutzman's Avatar
jstutzman is on a distinguished road
There are many of these trucks that get lifter noise that basically goes away after warm up. It is caused by a leaking Intake Manifold Gasket. When the antifreeze gets into the oil it causes sludge build up and will cause the lifter to start sticking. If you change the oil and it goes away or use some Marvels Mystery Oil and it goes away then comes back this will most likely be your issue. You may want to look at the years affected buy this but i know the 00 to 04 are prone to it. I have an 01 and just went thru this mess as did many others on this forum.
Old Jun 9, 2009 | 06:48 PM
Ok, thanks
Old Jun 10, 2009 | 01:06 PM
jstutzman's Avatar
No Problem, Just wondering if you found your problem yet.
xgiovannix12
Apr 9, 2013 10:58 AM
jamoka3
Mar 12, 2011 05:12 PM
wlorton
Dec 2, 2009 06:30 PM
Hellfish
Nov 11, 2009 09:28 PM
glenmoore670
Feb 15, 2006 11:08 PM
