2001 Blazer ltd 4wd, 4dr. Runs rough then stops
Old Nov 18, 2014 | 01:01 PM
TOMSBLZR2014's Avatar
TOMSBLZR2014 is on a distinguished road
Default 2001 Blazer ltd 4wd, 4dr. Runs rough then stops
2001 Blazer ltd 4wd, 4dr. After 250 mile trip my blz stop running as pulled of highway, it was a hot afternoon. It sounded like it was out gas, I had 3/4 tank. When I stopped I triied turning it over, It started, butt very rough then died. the temp gage was very hot. Towed it home. Next day started it again ran rough for a few moments then died. A mechanic friend of mine said the ignition didnot seem right. It would not run in the run position but would start running in the start position, very rough then stop. The same symptoms have happen over the past couple years, 2010, 2012, in very hot 100 degree weather. I thought I was running out of gas. I kept starting it until I got to a station. I would fill up, and I had more than 1/4 tank, Then would start and run Fine. I replaced the fuel pump in early 2014 . Any help would be greatly appreciated Thank You Tom
Old Nov 18, 2014 | 10:35 PM
rriddle3's Avatar
*Moved to '2nd Gen Tech'*
Old Nov 19, 2014 | 03:33 PM
Default Still learning to navigate the web page. Thanks
SteveBessert
Aug 7, 2014 04:29 AM
barnesto
31
Jun 11, 2014 07:12 PM
ryanmancl
Jul 2, 2010 04:44 PM
quontush
Jan 27, 2006 01:22 AM
