2001 Blazer Stuck in Reverse
Old May 27, 2014 | 09:10 PM
PhantomBlazer's Avatar
PhantomBlazer is on a distinguished road
Default 2001 Blazer Stuck in Reverse
I was backing my 2001 blazer out of my garage to put into the driveway and went all the way into the road. I tried putting it into drive to pull back into the driveway and straighten myself out, but it turns out it had only shifted into neutral. I thought I had gone to drive, but thinking I was mistaken, I attempted to shift to drive again, but the shifter went all the way to the bottom. In a panic, I tried shifting all the way back to park, but it only went back to reverse. The shifter is located on the steering column and freely moves the entire run, but does not shift any gears. I turned it off and now it doesn't turn back on cause it is stuck in reverse gear. Where do I start diagnosing this? (I did manage to get it back into the driveway with some neighbor's help and the wheels are blocked )
Thanks in advance!
Old May 27, 2014 | 09:32 PM
canuck blazer's Avatar
canuck blazer is on a distinguished road
will it go into the lower gears? did you by chance loose a motor mount ? Had that happen one time in a ford pick up couldn't shift into some gears, maybe a solinoid on the tranny?
Old May 27, 2014 | 10:24 PM
odat's Avatar
Also first thing check all your shift linkages - loose or missing bolts & nuts - keeper keys - bushings ect.
Old Jun 28, 2014 | 10:34 AM
So, some things came up and it took me a bit to get back to this. But it was indeed that the linkage had come loose. Does anyone have a diagram as to how this works? Is there a nut or something that holds the linkage on? I thought I had it fixed, just pushing on, but it came off again.
stingray74
Mar 5, 2015 08:27 PM
JandL_03
Nov 28, 2012 01:18 PM
adetandt
Nov 27, 2012 08:15 PM
cooljeep
Jul 21, 2010 01:42 PM
bigt61
May 29, 2007 01:56 PM
