2001 coolant leak
Old Sep 22, 2013 | 06:27 PM
mutineer's Avatar
mutineer is on a distinguished road
Default 2001 coolant leak
I have a 2001 I changed the oil today and was looking under to check for leaks when it started to leak coolant from the left rear of motor. It looks like it's coming from high up but I can't see exactly where. any ideas head gasket or intake maybe.
Old Sep 22, 2013 | 09:42 PM
A cooling system pressure test will tell where the leak is coming from. These engines are famous for leaky lower intake manifold gaskets, and they leak right where you say yours is leaking. The Felpro gasket set MS98002T will cure the problem if the parts are cleaned, installed and torqued correctly.
Old Sep 23, 2013 | 12:51 PM
mutineer's Avatar
ok thanks that's what i was thinking that it was prob intake
Old Sep 23, 2013 | 04:59 PM
Not a bad DIY job. There are plenty of threads in the "How-to" section. If it's your first time, plan on 4 to 6 hours. You will need an accurate torque wrench, both inch pound and foot pound. Before you remove the distributor, manually rotate the crankshaft clockwise and line up the rotor with the "6" on the distributor housing. When you're all done, camshaft retard needs to be checked/adjusted with a capable scan tool. Any questions, we can help.
Old Sep 23, 2013 | 05:45 PM
vegie_2's Avatar
vegie_2 is on a distinguished road
Like the captain said hook up a pressure tester you may think its one thing and turn out to be a heater hose like mine was
Old Sep 24, 2013 | 07:33 PM
aphaxad's Avatar
aphaxad is on a distinguished road
I also had a coolant leak. It turned out that the radiator was bad and the seams on it were coming apart and it was leaking through the seams. You might want to check on that as well.
Old Sep 25, 2013 | 10:00 AM
dobyken's Avatar
dobyken is on a distinguished road
I can't see how any non-professional can do it for the first time in 4-6 hours...just too much stuff to take off, clean and label so you know where it goes. It took me 2 days when I did mine. It's not a hard job..just time consuming when you don't know exactly what you're doing.
Old Sep 25, 2013 | 07:49 PM
A lot depends on your ability, and having the right tools available. The flat rate labor time using hand tools, (no power tools) is 3.8 hours.
m_coover99
Jun 8, 2015 06:59 PM
AcerDeucerQ
Dec 3, 2012 06:29 AM
BEAT MY JIMMY
Jul 21, 2010 01:13 PM
Skeeter Cruz
Mar 4, 2010 07:07 PM
TAZ454
Jan 28, 2008 10:11 AM
