2001 Jimmy Brakes Dragging Then Loosening Until Brakes Hit Again
I did already pump with caliper off and the piston did not really budge. I'm wondering if they should have. I'm trying to isolate the problem and determine if it is in fact caliper sticking or possibly the brake line insides acting like a check valve. Thanks
Pistons in calipers should have extended when pumping the brakes. Don't understand how you could have pushed the pistons in enough to get the new pads on if the calipers are stuck so bad they won't move under hydraulic pressure. That doesn't make sense.
Glad you got it fixed and thanks for letting us know what did the trick. Your thread may help someone in the future.
lidster
Dec 13, 2013 10:29 AM
00BlazerBoy
Aug 26, 2010 05:11 AM
Jrob11035
Apr 2, 2007 09:54 PM
