2001 Jimmy having major problems
Old Jan 27, 2010 | 10:17 PM
Blazeme's Avatar
Blazeme is on a distinguished road
Originally Posted by toaks1
I would def follow rridle's link, it is a good one. should cover all bases
here are a few of my thoughts:
did u replace the fuel filter when u replaced the fuel pump? Also did u use a quality name brand replacement pump? if u answer no to one or both of these then its possible that ur pump is bad again.
Try spraying a shot of starting fluid directly into the throttle body, if it fires right up and runs for a few seconds then u can be pretty sure that u have a fuel delivery issue and not an ignition issue. Also u should check the fuel pressure with a gage to make sure u are getting approx 60psi. If u have a plugged filter, or leaky line u wont get enough fuel to the engine which explains hte no start and poor performance. It also would explain the odor of gas
X2
I had problems with starting even though after it was started our Blazer seamed to run fine. Turned out to be the pump. Check the pressure during cranking , not just after It is started.
Blazeme
Old Jan 28, 2010 | 07:45 AM
ws6power1's Avatar
ws6power1 is on a distinguished road
Alright guys thanks for the info. I'll pick up a fuel pressure gauge today. Where will I hook the gauge to?
Old Jan 28, 2010 | 08:00 AM
This diagram shows the location of the fuel pressure test port.
Old Jan 29, 2010 | 08:55 PM
ws6power1's Avatar
Default Fuel pressure drops to 0! No start condition
Ok so I've had a no start condition for a couple days and finally tracked down the problem. I got a fuel pressure gauge and when I first turn the key on it jumps up to 62psi, but with in a few seconds it bleeds all the way down to zero? What could make it loose that much pressure? Delphi fuel pump and filter are only about 6 months old and I just replaced the regulator, because that was my first guess. Thanks
Old Jan 29, 2010 | 09:01 PM
Year??
Old Jan 29, 2010 | 09:04 PM
ws6power1's Avatar
2001 4x4 jimmy
Old Jan 29, 2010 | 10:05 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
fuel leak? only reason i could see it gaining pressure really quickly then losing it. or is there a check valve on the pump that could pressurize then lose it.
Old Jan 29, 2010 | 10:21 PM
rriddle3's Avatar
*COMBINING THREADS*
Since this is a continuation of the same problem let's keep it all in one thread so we can follow what you have done.
Have you followed through the diagnostic steps in the link I supplied? They will lead you to the cause of the pressure drop.
Old Jan 30, 2010 | 07:13 AM
ws6power1's Avatar
Yeah I'm trying to follow the link. How can I test prssure at the pump?
Old Jan 30, 2010 | 08:56 AM
You have to get the proper fittings to attach your pressure gauge at the fuel filter. The information is posted in other threads. You basically need to go from the tube fitting at the filter to a JIC connection. I can't remember the sizes off the top of my head, but I know they are posted.
Ryan Passini
Nov 11, 2012 10:51 PM
blasterdukes
Sep 5, 2011 04:40 PM
rugerfierro
Jan 23, 2011 07:46 PM
svd85
Mar 28, 2010 10:26 AM
jaeymers
22
Dec 26, 2007 10:33 AM
