2001 S10 A/C Stalls Car Quickly
Old Aug 18, 2010 | 10:48 AM
awild's Avatar
awild is on a distinguished road
Default 2001 S10 A/C Stalls Car Quickly
Been lurching around on this forum trying to find a fix but figured I'd just register and post my issue:
A/C off everything runs fine.
A/C on and the belt squeals like a stuck pig and stalls the engine within a minute.
-The A/C clutch never turns. I know there's only a couple of reasons why. Low charge is one, so....
-I put a gauge and r134 can on the low port and reads 45-50psi. Clutch still won't engage when filling. Has the whole can in at this point.
-Bad relay? I tried the "jumper" trick on the a/c relay. It does nothing to the clutch. Still won't engage.
What else can I check? I have a paper clip with electrical tape, I have a voltmeter (somewhere in my garage), and I have the low side pressure hose to read the psi.
-Thanks in advance!
PS - I have noticed a bit of water sloshing sound when I first start up and move the truck. Is it possible that something is blocking the system or is this a normal noise? Seems to be behind the glove box area.
Old Aug 18, 2010 | 11:52 AM
Surgin's Avatar
Surgin is on a distinguished road
The water sloshing is air in the heater core, flush it, it will stop the waterfall.
Sounds like the compressor is frozen, what you describe is the clutch engaging the compressor and its locked up internally. Thats why you get belt squeal and the truck stalls.
Justin
Old Aug 18, 2010 | 07:24 PM
x2 on the frozen A/C compressor. Can you turn the compressor by hand?
Old Aug 19, 2010 | 04:53 PM
awild's Avatar
Can't turn it by hand...I vote a stuck compressor too. Found one at a yard for $30 tho!
Old Aug 19, 2010 | 05:08 PM
Billy_Mac's Avatar
Billy_Mac is on a distinguished road
Be sure to flush system & replace orifice tube check oil in compressor or back to junkyard u go. (Might be good idea to repace dryer too)
roflwaffle08
Sep 19, 2011 06:43 PM
sdt83
May 30, 2011 04:05 PM
Survivor
Sep 10, 2009 06:07 PM
Swain
Aug 27, 2009 09:14 AM
KHARDA
Nov 21, 2008 03:37 PM
