2001 zR2 msd distributor install no start on 6 mark only cranks 1 tooth advanced
Old Feb 8, 2023 | 07:08 PM
Spide's Avatar
Spide is on a distinguished road
Default 2001 zR2 msd distributor install no start on 6 mark only cranks 1 tooth advanced
Hey guys ...I'm a 24 year ASE Technician and did a msd dist install on my 4.3 (w) zr2 blazer.....if I align all the timing marks it will putt on 2 cylinders and idle for 30 seconds and will run (with a 1345) only when advanced 1tooth on dist ...has anyone experienced this ...it was a basket case when I got it with everything tore down to the heads so I didn't pull the factory dist nor hear it run before hand BUT it doesn't miss with tooth advanced but acceleration is very poor so I checked the TPS and it's fine also replaced the spider inj with a Delco upgrade to MPFI. ANY OPINIONS WELCOME!
Old Feb 8, 2023 | 11:13 PM
Do you have a scanner that will read cam retard?
Old Feb 9, 2023 | 06:02 PM
Spide's Avatar
Yes but it actually has to crank before the scanner can be of use ....
Old Feb 10, 2023 | 06:36 PM
GeorgeLG's Avatar
So now it does not crank?
George
Wytepirate
Dec 10, 2022 09:18 AM
someone11
Mar 6, 2022 10:50 AM
bobs99
47
Feb 4, 2017 02:27 PM
pinhead65
May 5, 2015 08:55 AM
97blz4x4
Jan 2, 2007 03:53 PM
