How to time a 97 blazer 4.3 vortec
Old Jan 1, 2007 | 10:48 PM
97blz4x4's Avatar
97blz4x4 is an unknown quantity at this point
Default How to time a 97 blazer 4.3 vortec
hey yall,i just got through putting a timing chain set on my 97 blazer 4.3 vortec.i got the cam gear looking at 6 oclock and the crank gear at 12 oclock.ok how do you time it from here as far as the distributor.i lined the gears up with #4 at tdc on the compression stroke and then i turned the rotor looking at # 4.but that didnt start it.how do yall go about timing one?????help needed very bad
thanks alot
brandon
Old Jan 2, 2007 | 06:07 AM
Chevy Lover's Avatar
Default RE: How to time a 97 blazer 4.3 vortec
1 Align the indent hole on the driven gear with the paint mark on the distributor housing
Ensure that the distributor rotor segment points to the cap hold area
2 Align the slotted tang in the oil pump driveshaft with the distributor driveshaft. Rotate the oil pump driveshaft with a screwdriver if necessary
3 Install the distributor and distributor clamp. The flat in the distributor housing must point toward the front of the engine.
4 Once the distributor is fully seated, align the distributor rotor segment with the number 6 pointer (1) that is cast into the distributor base. If the distributor rotor segment does not come within a few degrees of the number 6 pointer (1), the gear mesh between the distributor and camshaft may be off a tooth or more. Repeat the procedure again in order to achieve proper alignment
[IMG]local://upfiles/2910/E95CEB4823574AE5BD30000F22EEBED6.gif[/IMG]
Old Jan 2, 2007 | 03:53 PM
Hanr3's Avatar
Timing is off the #1 piston.
#1 piston at TDC on compression stroke. Drivers side, furthest from the driver.
I dropped my distriburator in so that the rotor points to the #1 piston.
mrblonde108
Jul 17, 2017 07:52 PM
Puscypher
Apr 1, 2014 11:43 AM
ussexplorer
Mar 31, 2014 09:00 PM
Willmsy
Mar 11, 2013 02:50 PM
96blkblazer
Feb 26, 2009 04:29 PM
