2002 4.3 into a 1996 4.3 Blazer?
Old Jun 10, 2011 | 05:19 PM
USMarine1108's Avatar
USMarine1108 is on a distinguished road
Default 2002 4.3 into a 1996 4.3 Blazer?
I've got a 1996 4wd 4dr 4.3L Blazer. My buddy just pulled the 4.3L out of his 2002 2wd S-10 and put in a 350. What hurdles will I run into if I put the 02 4.3 into my 96 Blazer?
Just to clarify, my blazer is in great shape but has 160k on the clock. The motor ticks (I'm pretty sure it's a valve), minor oil leak from the front seal, oil pressure sits ~20psi at idle and doesn't have the "pep" it used to. His motor has 70k on it and had no issues when he pulled it. I can pick it up for $100.
Old Jun 10, 2011 | 05:24 PM
While the motor is out, tap the block out for 1/4" NPT to match up with your knock sensor.
If the '02 doesn't have provisions for an EGR valve, you will have to reuse your lower intake manifold, but I would recommend using the injection system from the '02.
If the '02 does have an EGR valve, you will need to drill/tap the lower intake manifold in the area of the t-stat for the coolant temp sensor.
Old Jun 12, 2011 | 01:56 PM
Well I just picked up the motor, trans, alternator, power steering pump, A/C compressor, air box, MAF, injection system, distributor, starter, hoses, water pump, fan, cruise control, pulley assembly and some other misc stuff for.........................
$150.
Would it be easier to use this trans with the motor, or will it not work because it's from a 2wd truck? I've read that the 96 bellhousing bolts are standard while the 02 bellhousing bolts are metric. True?
Because I got the motor with all of the sensors, I will just be able to plug the knock sensor into the existing 96 harness? If the plug is different, I'll just be able to splice the connector without issue, right?
KidBlazer
Nov 6, 2020 01:03 AM
ssmith0386
Oct 19, 2014 12:47 PM
SureShooter29
Mar 18, 2010 03:02 PM
poepoe624
Jan 10, 2010 11:48 AM
Boiler_81
Dec 2, 2008 10:04 AM
