2002 4.3l grinding sound
Old Oct 20, 2018 | 12:04 PM
Lastsamuel's Avatar
Lastsamuel is on a distinguished road
Default 2002 4.3l grinding sound
My 2002 blazer 4.3l Vortec is making a grinding sound upon excereration that stops when the pedal is eased up on. The sound could be light/thin metal or plastic. The sound seems to be coming from the drivers rear of the engine compartment. I have ruled out the PCV valve, Idler pully, tensioner pully, alrernator, power steering pump, ac compressor and belt.i am at a loss, please has anyone seen this before.
Old Oct 20, 2018 | 01:23 PM
odat's Avatar
just a thot, check your motor mounts, it may have a bad mount letting the engine rock and making a contact somewhere
Old Oct 20, 2018 | 05:07 PM
Lastsamuel's Avatar
Thank you, i will check those out. I am looking at the ignition rotor given the sound type and location as well. I will post an update directly.
Old Oct 20, 2018 | 07:28 PM
Rusty Nuts's Avatar
I agree with odat. The noise can be the fan blades hitting the radiator shroud.
Old Oct 20, 2018 | 07:31 PM
Lastsamuel's Avatar
Checked the fan clearance is ok. Thanks foe the thought any other ideas?
Old Oct 20, 2018 | 07:37 PM
Rusty Nuts's Avatar
Are there any signs of rubbing on the ends of the blades or the shroud?
Old Oct 20, 2018 | 07:39 PM
Lastsamuel's Avatar
Not that i can see.
slcblazer
Jul 26, 2013 10:29 PM
rspjr0310
Jan 19, 2010 12:41 PM
mattd
Sep 15, 2009 06:54 AM
willjones
Mar 6, 2008 06:21 PM
pigmak
Feb 23, 2007 10:14 AM
