2002 Blazer Front Axle Actuator Location
It's under your battery tray. You have to remove the battery and tray to get to it.
I believe you are referring to the Front Axle Actuator Solenoid Valve. Which I understand to be located on the firewall about in the center for an NV236 TC (four button). The Front Axle Actuator is located under the battery tray.
Did a quick search. This page has a pics of it's location about half way down the page. Front Drive Axle Vacuum Actuator Solenoid Valve?
I have a 2002 S10 Blazer. It shift into 4wd fine but when I go to put it back into 2 wheel there is a delay, sometime several miles and the a loud bang like someone hit the bottom of the vehicle with a hammer. I have changed out the vacuum front axle actuator (under the battery) and I am in the process of changing the Front Axle Actuator Solenoid Valve. Am I replacing the right items and is there anything else that I need to look at?
Typically a difference in propeller shaft RPM is what causes the "bang" on disengagement. If one tire is worn more than the others, that could cause it. The circumference of all 4 tires/wheels must be identical. All 4 tires and wheels must be the same size, same manufacturer is better yet. All 4 must be inflated equally.
Guest
Posts: n/a
Another thing you might want to check. I had a similar loud bang. The five 15mm bolts holding the tube and the plastic cable actuator to the front diff had backed out slightly.
If anyone has ever been in there good chance of improper torque.
Had a hell of a time finding it.
EDIT: Just to note, I am not suggesting this is the reason for your "clunk".
jnail
Jan 5, 2013 01:55 AM
a2dadamm
Nov 19, 2012 08:44 AM
Cassera
Jul 18, 2012 09:04 PM
19jimmy99
May 2, 2009 08:42 PM
