2002 Blazer ls Heater core removal
Old Jan 5, 2008 | 01:49 PM
  #21
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: 2002 Blazer ls Heater core removal
It sounds like you have left off or damaged/pinched your vacuum harness to the hvac control head. Check and make sure you have solid connections...it could also be that you twisted the box when you pryed it off of the firewall and broke the defroster valve (the little door inside the case).
Old Jan 5, 2008 | 05:09 PM
  #22
Chevy Lover's Avatar
It just so happens that I have the same problem right now. The air blows good through the vents but hardly at all from the defroster or the floor.
I found that this mode control unit seems to be weak 'cause if I assist it to full travel then I have full air flow.
This is on the drivers' side.
[IMG]local://upfiles/2910/67D1EE06003D4B27AF24C81C7DC89C8C.jpg[/IMG]
Old Jan 6, 2008 | 12:21 AM
  #23
sean bamf's Avatar
sean bamf is an unknown quantity at this point
thanks chevy lover but there is one thing that i dont undertsan about that is that when i turn the **** to chang the mode it doesnt like click anymore its werid
Old Jan 6, 2008 | 02:59 AM
  #24
Click? Where was it clicking before, at the switch?
Old Jan 6, 2008 | 03:01 AM
  #25
sean bamf's Avatar
like when you turn the know to put the air at your feet it would click it to place when you turned it
Old Jan 7, 2008 | 02:07 AM
  #26
Hmmm, check the switch....
Old Jan 7, 2008 | 09:11 AM
  #27
sean bamf's Avatar
i already did like evrything else works but the mode **** i tryed everything i could think of
Old Jan 7, 2008 | 10:50 AM
  #28
quinnman105's Avatar
quinnman105 is an unknown quantity at this point
Hmmmmmmmmmm thats weird
Old Jan 9, 2008 | 07:18 PM
  #29
sean bamf's Avatar
yeah, and everything is put back together right
bamablazer57
Apr 5, 2014 10:50 PM
error_401
Dec 10, 2013 04:07 PM
Psychotacon
Feb 3, 2013 10:32 PM
Static 90 C1500
Jan 21, 2013 07:43 PM
aspenpup
Jul 3, 2005 06:56 AM
