2002 Blazer misfire at idle.
Old Nov 24, 2022 | 02:27 AM
GeorgeLG's Avatar
We cant trust the misfire cylinder assignments until CMPR is within spec but it looks like 1,2 and 3 which is more than bank 1 if these hold up.
our fuel trims are good but the banks are the opposite (lean/rich), might turn out to be a clue later if we get stuck.
Your MAF reading is low at idle. When you get a chance, capture it at the 1-2 full throttle shift
Your 2 pre cat O2 sensors are switching OK but the post cat B1S2 sensor should be close to a flat line between 0.5 and 0.7V and its not. Whats the history on the cat?
Do you still have the ignition code?
Travel with the ability to measure fuel pressure ans spark so you cane see which it is the next time it dies and wont start.
George
Old Nov 25, 2022 | 12:43 PM
jwebb929's Avatar
jwebb929 is on a distinguished road
George
Ended up just replacing the distributor today. CMP retard is at 1. Cleared codes and let it idle. Seem to running a little better but still misfiring. Check the misfires in the scan. 1,2,3,4. Code came back to P0351 and now a P0300. I replaced the connector on the coil. Looks a little burnt but didn’t fix the issue. It’s not hard to start or anything. Hasn't died in 2 weeks. Don’t know the history of the cat as I only own it for about 1000 miles now. Rear O2 is still up and down. I did decide to check the fuel pressure today at the test port. Spikes at about 60 with KOEO. Drops to about 30 within seconds and holds. I did put a cheap Amazon pump and injector. I only did this cause it wasn’t running when I got it and didn’t know what I was getting in to so I didn’t want to dump $$$ in it to have a bad engine. Running fuel pressure is about 50 psi. As far as the P0351 what reading should I be getting st the harness?
Old Nov 25, 2022 | 01:28 PM
GeorgeLG's Avatar
CMPR is good so the misfire data is valid but not sure what it tells us. Interestingly this motor fires in descending sequential order and you have 4,3,2,1. Why not 5/6? Now that the distr is replaced and CMPR is in spec, is there any history with the crank sensor or reluctor wheel or a relearn?
That fuel pressure is no good and needs to be addressed. The brand of fuel pump is a notorious topic here with the universal rule that AC Delco or Delphi is the only way to go for a trouble free replacement. Same used to be true for the spiders but then ACD/Delphi was not available for a while. I see them back on Rock Auto but I don't know what the reliability situation is on these. You might be flirting with low pressure at idle and the voltage bump at speed may be just enough, until it isn't. You can cut your problem in half by testing at the fuel filter. If its in the intake plenum a regulator might be worth a try if your trying to save money and salvage the work already performed. This could be the whole problem.
P300 was only a matter of time with those misfires counts.
P0351 can cast a wide net. The PCM does not like the way the primary circuit is behaving but its the entire circuit that's in play not just the ICM or PCM which is where everyone wants to go first. Can be:
  • Power or grounds to the ICM/coil/PCM
  • Signal wiring from PCM/ICM/coil
  • The secondary circuit can be a mess causing preturbed primary circuit (plugs/wires/distr/high tension coil lead)
  • The ICM/coil/PCM
Before getting too fancy on this one any easy and important first check is the net voltage to the ICM (backprobed power and ground) when it runs crappy and +V at the coil, same condition.
A spent cat does not in itself cause the engine to run crappy, just increase emissions ans flunk inspection. However, a damaged cat from say a rich fuel mixture or coolant contamination can cause the catalyst metal to start flaking off and plug the exhaust. The resultant high back pressure can cause the truck to run crappy. Might be worth a look if the fuel pressure fix does not fix everything.
George
Old Nov 26, 2022 | 04:32 PM
jwebb929's Avatar
  • The ICM/coil/PCM
George
I really appreciate the help with this. I ended up getting the P0351 to go way. The misfire isn’t as bad anymore. I ended up selling it today as is. Tired of throwing money and time at it. Thanks for all the help.
Old Nov 26, 2022 | 04:38 PM
GeorgeLG's Avatar
How did you get the P0351 to go away?
George
Old Nov 26, 2022 | 05:04 PM
jwebb929's Avatar
George
I swap the cheap coil and ICM back out to the oem vs the cheap $20 one from Amazon.
Old Nov 26, 2022 | 05:17 PM
GeorgeLG's Avatar
Thanks for the follow up.
George
bagginses
May 27, 2021 11:41 PM
Justin56
18
Jul 31, 2017 10:16 AM
billfrank85
Jul 9, 2012 03:07 AM
jeffr_ca
Jul 19, 2010 10:25 AM
Cyberlight
May 17, 2010 09:09 PM
