2002 dome light .. how to get to the bulb?
Old Apr 13, 2012 | 01:21 AM
contour1's Avatar
contour1 is on a distinguished road
Default 2002 dome light .. how to get to the bulb?
Do you pry the clear cover off? Twist the housing.. squeeze in on a certain spot? I find nothing in the owners manual except bulb recommendations..
Problem is all lights work except dome.. which WILL work if given a little "TAP".. not quite as hard as Brock Lesnar hit Cena in the mouth with, but more of a backknuckle rap.. so.. i wanna check for loose wires.. loose bulb.. etc.. anyone got anything?? Thanks..
Old Apr 13, 2012 | 02:09 AM
50lb_cat's Avatar
I believe you just take a small screwdriver and pry it off, someone can correct me if I'm wrong lol.
Old Apr 13, 2012 | 09:00 AM
wyzardd's Avatar
wyzardd is on a distinguished road
There should be a slight notch on the front or back (not the sides, in other words), pry it off from there with a thin screwdriver. Takes a little more force than you'd expect (well, more than I expected anyway) but not enough that you start worrying about damaging something. It will then go flying off into the back and land under a seat where you can't reach it from the front.
Old Apr 14, 2012 | 02:20 AM
contour1's Avatar
Thanks alot!!
97blazer8488
Nov 4, 2015 04:48 AM
dano440
May 11, 2012 06:57 PM
mboggess
Jul 16, 2008 09:00 PM
ltown21
Jul 18, 2007 10:00 PM
Maxima570
Nov 22, 2005 04:06 PM
