2002 Power window regulator installation
Old Mar 6, 2012 | 10:01 AM
blanco36's Avatar
blanco36 is on a distinguished road
Default 2002 Power window regulator installation
How hard is it to install a new power window regulator? Any info on this matter will be greatly appreciated.
Old Mar 7, 2012 | 12:35 AM
onebadsuv's Avatar
onebadsuv is on a distinguished road
Actually it is fairly straight forward - remove the door panel and the factory rivets holding the defective part in - easy to drill out . Use bolts or new pop rivets if available to reinstall replacement regulator . Once You pull the door panel and door liner moisture barrier it will all be revealed .... how are the door lock actuators working ? ...... since You have it open anyway ? My '95 driver's side needs both
Old Jul 30, 2012 | 07:56 AM
Echeban's Avatar
Echeban is on a distinguished road
Default window stuck down, how do I get it up?
My driver window is stuck down. I removed the panel and moist barrier. When I apply 12.5 DCV to the motor directly, it does not move, but takes current and makes a typical little noise of a motor taking current. Reverse the polarity and does the same. I was going to order a new regulator but my Haynes manual says that I must have the window all the way up before drilling out the rivets. How do I get it up?
comandoed
Aug 25, 2013 10:03 PM
jimhens82
Oct 21, 2012 06:37 PM
my 88
May 16, 2010 05:36 PM
degaine_designs
Aug 10, 2009 03:55 PM
rhs856
Jul 28, 2009 10:34 PM
