2002 ZR2 Blazer Hesitation Problem
Old Feb 28, 2005 | 10:49 PM
jp5162's Avatar
jp5162 is an unknown quantity at this point
Default 2002 ZR2 Blazer Hesitation Problem
Vehicle has a good hesitation between 1500 and 2000 rpms only. Otherwise, runs fine. Fuel filter, spark plugs, air filter have been changed. Vehicle has only 40,000 miles on it. Any suggestions for this repair would be highly appreciated.
Old Mar 1, 2005 | 06:55 PM
benzodogg's Avatar
benzodogg is an unknown quantity at this point
Default RE: 2002 ZR2 Blazer Hesitation Problem
check mass air flow sensor, and trans fluid
Old Mar 1, 2005 | 09:38 PM
jp5162's Avatar
Wouldn't mass air flow sensor throw a code? Why would this cause it at only these rpms, wouldn't it happen constantly? As for transmission fluid - fluid is full - why would fluid do it as these rpms only anyway?
Old Mar 1, 2005 | 10:11 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
check for corrosion on the terminals on the coil pack, or the wires may be bad.
jimhens82
Jun 22, 2015 10:30 AM
skygodtj
May 23, 2012 09:08 PM
BLaKZr2Bob
Jan 22, 2010 07:46 PM
wahhen
Jun 10, 2005 10:56 PM
