2003 -> 2001 4.3 engine swap. Any issues?
Old Sep 17, 2021 | 07:28 AM
VIBlazer's Avatar
VIBlazer is on a distinguished road
Default 2003 -> 2001 4.3 engine swap. Any issues?
Need some advice. I have a 2001 4x4 Jimmy which my Dad overheated severely... cylinders 4&6 are no longer functional. It isn't blowing pressure into the crankcase or cooling system and there's no coolant in the oil so I'm guessing stuck or burnt valves?
Anyway. I have a line on a 2003 4x4 S10 with a good engine & transmission. Thinking about buying it cheap and having the engine alone (or the engine & transmission) swapped over by a mechanic. Is this doable? Is there anything which I need to look out for?
Old Sep 17, 2021 | 10:24 AM
I believe the knock sensors are different, so you may have to get creative in mounting the old-style sensor (fairly simple) and you may need to swap over stuff like intake and/or exhaust manifolds, depending on which emission controls the two engines have, but it should work otherwise. To the best of my knowledge, anyway. One of the smarter guys on the forum should be along soon to correct me if I'm wrong.
Old Sep 19, 2021 | 08:43 AM
When I put an 03 engine in my 99. Mechanic had to install the knock sensor, and also use intake manifold from the 99 as it didn't have the egr opening
Old Sep 19, 2021 | 09:53 AM
LesMyer's Avatar
Knock sensors should be the same. 2001 was first year for the second design. However, 2003 doesnt have EGR valve and i believe AIR system is either not there or quite different. Solution is to use the intake and exhaust manifolds from the 2001. The rest is identical as long as they are both 4x4 or 2x2. If different there, switch the oil pan.
Ncpunx
Jan 15, 2019 07:11 AM
orangewing
Aug 6, 2017 09:28 AM
Dadatone
Feb 23, 2013 08:23 PM
barter1
Dec 10, 2012 08:35 AM
thejimmy
Aug 17, 2009 12:05 PM
