2003 4.3 s10 swap into 2000 blazer
I’ve got a 2000 4wd 5speed blazer with a bad 4.3 and I want to put the 4.3 out of my 2003 2wd auto s10 pick up anyone know what all I need to swap off my blazers motor on to the good motor?
I am doing a similar swap. I have a 2000 Blazer 2wd automatic with a bad 4.3 engine, and want to pull a good engine from a 2003 Blazer 2wd 5 speed manual.
I understand that the knock sensor thread on the engine block will need to be drilled out for a bigger hole for the different sensor.
The fuel injectors seem to be different too, as well as the EGR system, and will need to swap the intake and exhaust manifolds from the 2000 engine.
Does anyone know if the crank and cam position sensors are different, and if anything else is different? I heard the bolts that hold the engine and trans bell housing are different thread between certain years.
Thanks.
Thanks.
Thanks.
Thanks.
