2003 ac clutch
Old May 20, 2009 | 11:19 AM
gpaqu's Avatar
gpaqu is on a distinguished road
Default 2003 ac clutch
my ac clutch would not pull in so I jumped the relay, still did not pull in, so then I gave it a slight tap and it pulled in I did this many of times, some times not many it would pull in by itself, I sprayed it with wd40, is there a proper way to solve this problem?
Old May 20, 2009 | 12:06 PM
Sounds like you either have too large of an air gap or your clutch magnet is weak.
I suppose it could be a wiring/connection problem between the relay and the clutch itself. You could test this theory by applying voltage and ground directly to the clutch and see if your results differ.
Old May 20, 2009 | 06:08 PM
brcidd's Avatar
brcidd is an unknown quantity at this point
clutch air gap from factory is .010" to .040" so measure yours and set it closer if too wide- you can borrow the tool from Autozone
Old May 22, 2009 | 10:04 PM
hkellogg's Avatar
hkellogg is an unknown quantity at this point
best way to check this is to see how much pressure is in the system with a manifold gauge set. You might have to vac the system out and hold vacuum then charge the system to get the clutch to engage. The Low pressure should send signal once there is enough pressure in the system for the clutch to cycle its basically a failsafe mechanism so the compressor won't ruin itself
MintyMadness
Jul 13, 2011 12:37 AM
speedfreak81
Oct 13, 2009 06:58 AM
Red03
Sep 25, 2008 08:37 PM
Plage50
Jun 6, 2007 09:00 AM
m00nwater
May 18, 2005 09:27 AM
