2003 Blazer
Old Dec 24, 2008 | 11:08 PM
dacop's Avatar
dacop is an unknown quantity at this point
Default RE: 2003 Blazer
Well I replaced the MAP sensor and after a trip around the block the light went off, but 5 minutes later cameback on . I also noticedit hesitatessometimesafter a stop (red light or stop sign). I also changed the air filter and PCV valve.
What should be my next move? The p0107 code also mentions the Mass Air Flow sensor as a possible cause. Do I try this or stop wasting money on parts and take it to a shop?[/align]
Old Dec 25, 2008 | 12:17 AM
Johns1987Blazer's Avatar
Johns1987Blazer is an unknown quantity at this point
Check your air filter first, sometimes a dirty air filter will result in "MAF or VAF low voltage/low response" and make it run rich.
Old Dec 25, 2008 | 12:40 AM
dacop's Avatar
Brand new Fram air filter was put in at the same time as the MAP sensor.
Old Dec 25, 2008 | 08:51 AM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
Search this site for MAF cleaning-you can do it and cost is only time and cleaner. Does the cat. converter rattle? Had one or two of these where it kicked this code but ultimately had a bad cat. good luck JP PS may have a bad MAF but cleaning it first is the route to go and we'll go from there! JP-Merry Christmas[X(]
Old Dec 25, 2008 | 09:59 AM
The diagnostic procedure never mentions the MAF sensor...
Now this is why I always advocate of proper testing prior to component replacement.
Here is one thing that sticks out at the tail end of the diagnostic procedure linked to above:
10. The 5 volt reference of the VCM supply is shared by the MAP, FTP, TP, and EGR position sensors. A short to ground at ANY of the sensors 5 volt reference circuits OR an internally shorted sensor may cause this DTC to set.
MAP = Manifold Absolute Pressure
FTP = Fuel Tank Pressure
TP = Throttle Position
EGR = Exhaust Gas Recirculation
Old Dec 25, 2008 | 10:24 AM
the reason I mentioned MAF sensor was because two previous posters mentioned the MAF as being in the loop. Thus the cleaning..I did not look up the code myself. JP
Old Dec 25, 2008 | 10:26 AM
I really was not responding to you JP, but to the OP. I should have clarified as these stupid "(in reply to xxxx)" tags are useless when you do a quick reply.
Old Dec 25, 2008 | 05:46 PM
dacop's Avatar
I am taking the truck to a local repair shop tomorrow. Thanks for everyone's help.
Old Dec 25, 2008 | 08:22 PM
If you would...let us know how you make out. JP
Old Dec 25, 2008 | 08:30 PM
dacop's Avatar
I will for sure.
