2003 Blazer AC LP valve
Old Jun 19, 2008 | 03:06 PM
numus's Avatar
numus is an unknown quantity at this point
Default 2003 Blazer AC LP valve
Where exactly is this port located on the 2003 chevy blazer. I am trying to recharge my ac but i found 2 ports with black dustcaps.. One on a U bent metal going from the bottom of the evap it looks like and into a giant black box (cant really see where all the hoses are going) and one is on the side of a Delphi Temp cylinder... Which should i use to recharge...
Old Jun 19, 2008 | 03:10 PM
Default RE: 2003 Blazer AC LP valve
Use the one that the recharge fitting fits onto... They are different sizes, HP is larger than the LP if I remember correctly.
*Moving to 2nd Gen Tech* - Please choose the appropriate forum section within General Tech to better segregate the information.
Old Jun 19, 2008 | 03:17 PM
numus's Avatar
When my AC is on max the pressure is about 65 psi.. when teh AC cuts off it climbs to the 150 psi range...
I know i cant recharge it because the pressure is to high but is there anything to look for before i take it to a mechanic
Old Jun 20, 2008 | 02:29 PM
numus's Avatar
I am an idiot.. for some reason when i saw put it on max a/c i put the switch to max a/c and the other one all the way up to 4.. that explains why my pressure was so high.. i dropped it to 1 and it dropped to the fill mark and charged the a/c.. works great now..
marksoftball
Nov 29, 2014 09:27 PM
Chevy33
Mar 25, 2012 11:52 AM
89Recon
Oct 22, 2011 05:50 PM
IndianaBlazerGirl
Sep 6, 2011 06:22 PM
bigdaddykane93
Dec 16, 2010 04:28 PM
