2003 BLAZER FACTORY FOG LIGHTS
Old Dec 20, 2008 | 03:57 PM
sav24dl's Avatar
sav24dl is an unknown quantity at this point
Default 2003 BLAZER FACTORY FOG LIGHTS
I HAVE FOUND ON THE INTERNET, THE FACTORY FOG LIGHT ASSEMBLIES THAT REPLACE THE STANDARD TURN SIGNAL ASSEMBLIES IN THE GRILL, ALSO FOUND THE COMPLETE FRONT HEADLIGHT WIRING ASSEMBLY THAT ALSO INCLUDES THE WIRING FOR THE FOG LIGHTS.
NEXT I LOCATE THE FACTORY LIGHT SWITCH ASSEMBLY INCLUDING THE FOG LIGHT SWITCH, IS THERE A FACTORY WIRING INSIDE MY 2003BLAZER THAT RUNS FROM THE FUZE BOX ASSEMBLY TO THE FOG LIGHT SWITCH, OR DO I NEED TO LOCATE THAT TOO? THIS WOULD BE A NICE FACTORY LOOKING UPGRADE ESPICALLY IF I USED AFTERMARKET FOG LIGHT BULBS.
Old Dec 20, 2008 | 04:17 PM
Default RE: 2003 BLAZER FACTORY FOG LIGHTS
Wrong section... DIY Submissions/Discussions is for submission and discussion of complete DIY articles.
*Moving to 2nd Gen Tech*
It is likely that you will have the wiring. Here is the kicker... You will have to get the PCM programmed to turn this option on. The fog switch just switches a wire that runs to the BCM. Without the proper programming, having all of the hardware is meaningless. The next kicker is that you cannot just walk into a GM dealership and have them turn on this feature. No one there knows the specific modification necessary. How they do it is if you can find the VIN from a vehicle that has this option PLUS all of the same options you have and the same year, then you can use that VIN to reprogram your PCM/BCM.
I would wire the interior switch to a relay inorder to control the lights. You will need to find some wiring diagrams to know what wires to use and where to find them.
Old Dec 20, 2008 | 05:09 PM
ZLover4Life's Avatar
ZLover4Life is an unknown quantity at this point
SWANNERZ
Aug 13, 2014 05:05 PM
Kai
Nov 2, 2010 11:36 AM
brad_blazer
Oct 28, 2010 11:13 PM
Dogger
Nov 15, 2009 08:13 PM
igot10pinitis
Oct 2, 2008 09:33 PM
