Starter problems?
Old Dec 19, 2008 | 02:08 PM
bobbot's Avatar
bobbot is an unknown quantity at this point
Default Starter problems?
I have a 98 4x4 4.3l automatic LS, I let it set for 4 days and when I tried to start it it cranked but wouldn't run. I didn't run the starter constantly but I did try it until the battery got low. Charged the battery, got it tested, cleaned the cablles and terminals, andreinstaled it and got no cranking at all. In about 10 minutes the voltmeter showed 10 volts. I checked the fuses with a meter and they are good. Could my starter be the culprit? The truck has 158000 mi on it and I've only had it for a couple of months but so far it has been good running and until today never failed to start almost instantly. HELP!
Old Dec 19, 2008 | 02:33 PM
lowe42's Avatar
lowe42 is an unknown quantity at this point
Default RE: Starter problems?
Had a simular problem with mine, the leads on the starter were loose/dirty. Make sure the connections on the starter are good and snug. You will have to go threw the front passenger wheel well to get at it.
Old Dec 19, 2008 | 02:36 PM
bobbot's Avatar
That sounds like fun. Thanks I'll give it a shot. Anyone else?
Old Dec 19, 2008 | 10:05 PM
hillbillyinOhio's Avatar
was there rain or heavy snow around this time? wondering about moisture and dist cap.
Old Dec 20, 2008 | 05:56 AM
bobbot's Avatar
Yes it was very humid and damp. Everything on the dash is slightly nuts too. I can here relays buzzing and the needles are acting strange. They jump and swing to positions that are not normal.
Old Dec 20, 2008 | 11:48 AM
dBsound's Avatar
dBsound is an unknown quantity at this point
Bad ground???
Old Dec 20, 2008 | 12:07 PM
bobbot's Avatar
Bad ground? possible. I took the batt in for load test and recharge the cable ends looked bad so I scraped them but my main dislike for the side post is that cleaning the post is nearly impossible without a special tool.
I've been outside freezing my *** off and the only thing that made any difference at all was rocking the screws in the cables back an forth then tightening them down again that made the gauges go back to normal and the wierd buzzing from under the dash stop. All of the displays and warning lamps came back too. When I turned the key to start it just went dead again and only the continued fussing with the cables restored it. I woud also note that the battery is back down to 10-11 volts and will need to be recharged again.
Old Dec 20, 2008 | 12:24 PM
If moving around the connections at the starter helped, then it is clear that you have a corrosion problem on one or more of the terminals. I would disconnect all of the terminals and give them a thorough cleaning.
Old Dec 21, 2008 | 06:53 AM
bobbot's Avatar
Recharged and replaced the cables, everything is back to normal. I've never seen that much wierd crap go on with nothing but bad cables before. There wasn't a lot of visible corrosion but the cable ends were sealed after a fashion. insde the plastic covering was nearly dissolved. the failure was probably just co-incidental to the discharge.
jdmmario
Oct 25, 2014 06:25 PM
Woot!
Mar 24, 2008 12:15 PM
Tymaraux
Mar 18, 2008 02:49 PM
keithscianna
Jun 23, 2006 08:56 PM
Joshua M. Smith
Sep 19, 2005 02:57 PM
