2003 chevy blazer
Old May 1, 2010 | 11:37 AM
moody69's Avatar
moody69 is on a distinguished road
Default 2003 chevy blazer
This is my problem i need help with last winter my truck was running fine idleing then it just stopped I am not getting any fuel to the fuel filter now. I need help where is the fuel pump relay and is there fuses i should be checking before i drop the fuel tank and replace the fuel pump thank you very much. Walking
Old May 1, 2010 | 04:05 PM
Fuel pump relay is in the underhood fuse/relay center. You can hot wire the pump by placing a fused jumper wire in place of the relay to effectively hot wire the pump. If it still does not run, then your pump is bad.
hlaverty06
Mar 5, 2014 07:14 PM
AaronGene02
Jan 24, 2010 11:38 AM
kmartin
Apr 25, 2009 11:53 AM
downja
Aug 19, 2008 08:32 PM
celchlepp
Jan 10, 2008 01:24 AM
