2004 Blazer LS 4x4 squeaking
Old Aug 11, 2022 | 12:08 PM
elwaykid's Avatar
elwaykid is on a distinguished road
Default 2004 Blazer LS 4x4 squeaking
There is a squeak when I accelerate and goes fast as I press pedal. Once I take foot off the gas pedal the squeaking slowly stops . Blazer rolls good . Funny thing is there is NO squeaking when going in reverse .
I replaced the brakes rotors calipers
Drive shaft ? Unjoints ?
Thanks in advance
Old Aug 15, 2022 | 01:26 PM
El_Beautor's Avatar
Is it a brake squeak, from worn brake pads?
If it's not a brake sound, then the first place I'd check is the u-joints on the driveshaft. Your symptoms sound like a worn u-joint to me.
Old Aug 17, 2022 | 09:56 AM
elwaykid's Avatar
It was the unjoints
had both drive shaft unjoints replaced
blazer sat for 2 years
Problem solved
Thanks
Old Aug 17, 2022 | 10:05 AM
GeorgeLG's Avatar
Nice call.
George
Old Aug 18, 2022 | 02:46 PM
El_Beautor's Avatar
Originally Posted by elwaykid
It was the unjoints
Problem solved
Thanks
Thanks for letting us know the results. It's always good to close the loop like that.
Originally Posted by GeorgeLG
Nice call.
George
Thanks George! I don't know nearly as much as you do about cars, but it is fun to be able to help and to get one right now and then.
Old Aug 18, 2022 | 03:31 PM
GeorgeLG's Avatar
It’s very satisfying when you help somebody figure it out
jmac219
Oct 6, 2021 09:49 AM
Capt-K5
Sep 7, 2011 04:32 AM
Blazer King 1998
Jan 27, 2011 08:16 AM
blazeveryday
Aug 8, 2009 08:18 AM
BobTheBlazer
19
Jun 2, 2008 03:35 PM
