front drivers side diff seal replacenent
Old Mar 24, 2013 | 06:30 PM
norteno's Avatar
norteno is on a distinguished road
Default front drivers side diff seal replacenent
I began changing the drivers side diff seal. here are some pics. I 1. used impact to loosen hub nut, 2. wire brushed all nuts, bolts and brackets, 3. PB blasted nuts, bolts and brackets and let sit overnight, 4. removed cotter pins with needle nose pliers and vice grips, 4. loosened castle nuts with impact wrench and box end wrench and separated ball joints and tie rod end by all of the methods shown in pics. I am replacing both ball joints so I didn't worry about tearing up boots, but they came off with beating with hammer. I had my floor jack lifting up at the end of the lower control arm. This made it easier for the ball studs to pop out. 5. used gear puller to push CV joint in. 6. Loosened lower shock bolt for clearance. 7. I disconnected ABS sensor by unplugging elec connector behind splash guard, following the wire and unbolting three other bolts including one on the upper ball joint. I did this so I could remove spindle with wheel hub bearing attached. 8. Removed spindle. 9. Used large screwdriver to snap out CV joint from underneath the truck and pulled it out to expose diff cover with seal in it. I removed diff drain bolt. That's as far as I got today. Thanks to Captain Hook and everyone else who got back to me with all the right advice and knowledge.
Attached Thumbnails front drivers side diff seal replacenent-img00193-20130303-1521-1-.jpg   front drivers side diff seal replacenent-img00205-20130323-1402.jpg   front drivers side diff seal replacenent-img00227-20130323-2032.jpg   front drivers side diff seal replacenent-img00202-20130323-1336.jpg   front drivers side diff seal replacenent-img00206-20130323-1427.jpg
front drivers side diff seal replacenent-img00210-20130323-1541.jpg   front drivers side diff seal replacenent-img00212-20130323-1542.jpg   front drivers side diff seal replacenent-img00214-20130323-1543.jpg   front drivers side diff seal replacenent-img00216-20130323-1647.jpg   front drivers side diff seal replacenent-img00215-20130323-1647.jpg
front drivers side diff seal replacenent-img00217-20130323-1649.jpg   front drivers side diff seal replacenent-img00221-20130323-1656.jpg   front drivers side diff seal replacenent-img00223-20130323-1734.jpg   front drivers side diff seal replacenent-img00226-20130323-2030.jpg   front drivers side diff seal replacenent-img00228-20130324-1214.jpg
Old Mar 24, 2013 | 07:18 PM
norteno's Avatar
Default front diff drivers side seal replacement, pg 2
some more pics.
Attached Thumbnails front drivers side diff seal replacenent-img00231-20130324-1228.jpg   front drivers side diff seal replacenent-img00232-20130324-1247.jpg   front drivers side diff seal replacenent-img00234-20130324-1257.jpg   front drivers side diff seal replacenent-img00235-20130324-1320.jpg
Old Aug 19, 2022 | 10:11 PM
CODEE_'s Avatar
CODEE_ is on a distinguished road
Originally Posted by norteno
some more pics.
Don't know if you're still around on this fourm but did you use the seal with the metal nubs on the back for the replacement or without? They sell two different kinds
evomat
Sep 30, 2011 05:18 AM
DCFluX
14
Sep 3, 2010 12:01 AM
Frankiesurf
Jun 20, 2010 11:07 AM
Mapoftazifosho
Oct 26, 2007 10:26 AM
DCFluX
Oct 5, 2007 06:11 PM
