2005 ZR2 z Radiator flush help
Just picked up a 2005 zr2 Blazer and went to do a radiator flush but can't locate a drain plug, what am I missing. I found what looks like it should be the drain but it has no plug. Is this not the drain, any thoughts? Thanks
How's the quality of the coolant? If it seems really bad, it may be a good idea to just replace the radiator.
When I bought my 4WD 2Door Blazer with 110,000 miles on it at the time, A/C system had no heat. Soon after driving it, the water pump went bad and I replaced it.
After replacing the water pump, I decided to flush the heater core, and that's when I discovered an orange snot that was clogging it up. It still had the factory original DexCool that caused these sorts of problems. That's when I decided to replace everything in the cooling system.
My radiator was full of black crap that settled to the bottom and presumable into the lower hose so even if I could open the drain it wouldn't drain much. I couldn't get to the hose. so I took it to a radiator shop and for $400 they drained everything, replaced the rad and now I enjoy opening the cap and seeing a clean light green coolant.
BTJustice
15
01-05-2008 12:44 PM
