2nd Gen Blazer: Major systems to monitor to prevent trouble later
2nd Gen Blazer: Major systems to monitor to prevent trouble later?
Hi All,
From my .sig file you'll see I have a 99 Blazer LT, 4WD, AT. It has about 135,000 miles on it and I would like to keep using it for at least another 30k to 40k miles.
I've been doing I think a pretty good job with maintaining it and servicing the major systems but I was wondering if there is anything for which I should be keeping an eye out?
In the last few years I've done maintenance or replaced parts on the following:
Things I've never had to service include:
The only outstanding issue now is the SIR trouble-light goes on and off now and then.
Are there other systems besides those that I have not had to service that might be problem down the road?
Of the systems that I have not needed to service, are any of them prone to becoming a problem someday? Are any probably not going to an issue?
Thanks
Christine
P.S. Added later: I have replaced the oil cooler lines the run from the rear of the engine block to the remote oil filter. Thanks to jck1961 for asking about that repair.
- Transmission rebuilt with extra cooler installed
- new front suspension components (ball joints, tie rod ends, idler arms, pitman arm, front wheel bearings)
- regular fluid checks and replacement (engine oil, front and rear axle oil, transfer case, transmission, engine coolant, brake fluid)
- fuel filter, air filter
- under-hood vacuum hoses replaced
- cooling system hoses replaced
- front shocks replaced
- debris cleared from under windshield grill and door jams
- serpentine belt
- Cap, rotor Spark plugs and wires replacement (to be done soon)
- exhaust system from cat-conv. back replaced
- brakes, front, rear, park, pads/shoes and general maintenance
- universal joints on driveshafts
- power steering system
- body wiring harness
- engine compartment wiring harness
- rear axle seals/bearings
- front transaxle (including cv-joints and front axles)
- rear shocks/springs
- fuel tank/pump
- starter
- exhaust from engine to far end of cat-conv.
- body, corrosion or paint peeling
- alternator/charging system
Thanks
Christine
Last edited by christine_208; 10-09-2017 at 12:35 PM. Reason: forgot "?" in title, updated list
The first thing that comes to mind that is not on your list is the oil cooler lines. There are two pair of lines, one on each side of the oil filter.
jck1961,
It is funny you mentioned that. Replacing those oil cooler lines that go along the engine block was the last thing I did.
I can only guess that I did not include doing that on my list because my subconscious was blocking the traumatic memory of doing the repair.
Damn was that an annoying repair to do. LOL
Thanks for taking the time to look over my list!
Christine
Christine
chalk one up for the Zr2's , I didn't have to jack the motor to pull out these lines. it was a piece of cake.
I would try to avoid gasoline with ethanol in it. Why --phase separation, especially when the vehicle sits for awhile. That may be difficult to do in ID= Idaho. Here in SC gas has 10% ethanol and they would like to go to 15%. The best example of what ethanol does to gas is in lawn mowers, chain saws, weed eaters, and other small engines which have carbs and tend to sit a lot between seasons. They have to have the fuel system cleaned to get them going again after a season of sitting.
I recommend keeping the old serp. belt as a spare. Wrap it in a plastic bag and store it in one of the compartments in the rear wheel area. You will be glad you have it if the serp. belt ever breaks and all the parts stores are closed or far away.
greene
04-11-2010 06:38 PM
