#3 Sparkplug Help
Old Oct 21, 2007 | 10:28 PM
  #31
Default RE: #3 Sparkplug Help
The only touchy subject in this thread was your **** poor attitude towards those attempting to HELP you. Sorry, maybe we just shouldn't even bother with your questions any longer. And I'll add hypocritical to the definition of your attitude in this thread as well judging by your "ignore the tones & stick to the facts" comment. Act like a *****, be treated like a *****. Common courtesy goes a long way when you are the one with your hand out asking for help. Learn some.
Still with your hand out huh?
GM FSM Spark Plug Removal Procedure:
REMOVAL PROCEDURE
  1. Remove the spark plug wires.
  2. Loosen each spark plug one or two turns. Most spark plug are best removed from wheel wells.
  3. Brush or air blast away any dirt from around the spark plugs.
  4. Remove the spark plugs one at a time and place each plug in a tray marked with the corresponding cylinder numbers.
INSTALLATION PROCEDURE
  1. Properly position each spark plug washer.
  2. Inspect each spark plug gap. Adjust each plug as needed. Specification Spark plug gap: 1.524 mm (0.060 in) .
  3. Install the spark plugs one at a time with the corresponding cylinder numbers. Tighten the spark plugs to 15 N.m (11 lb ft) .
  4. Install the spark plug wires.
*Thread Closed*
rdhack
Apr 28, 2008 10:21 AM
scottyk
Apr 6, 2007 08:52 AM
cody32401
Nov 10, 2006 05:49 AM
Rahmir
Aug 16, 2005 12:52 PM
