3rd brake light question and other question.
i have found both fuses for the (chmsl) but it says im suppose to have a relay for it in the under the hood fuse box. which in my case is not there at all, and when i look at the fuse box there is no female plugs in there to accept the relay. my 3rd brake light has not worked since i got it. any info on this issue?
second question: not sure if anyone has had this happen to them. BUT, sometimes when i go to shift after hitting the brakes and comming to a stop. my abs light and emergency light pop on for a couple seconds then go off as if nothing happened, and there is no codes at all. and sorry if i asked this question before because i cant remember for crap lately.
ORIGINAL: Numba1Sean
where abouts it that located?
ORIGINAL: 95Blzr
Could the light also be caused from low fluid in the reservoir?
It could also be a momentary loss of WSS (wheel speed sensor) signal which could be caused by a dirty reluctor ring in the front wheel bearing assemblies. But check the parking brake pedal and brake pads / fluid reservoir first.
dano440
May 11, 2012 06:57 PM
