3rd brake light question and other question.
Old Jan 6, 2009 | 11:58 AM
Numba1Sean's Avatar
Numba1Sean is an unknown quantity at this point
Default 3rd brake light question and other question.
i have found both fuses for the (chmsl) but it says im suppose to have a relay for it in the under the hood fuse box. which in my case is not there at all, and when i look at the fuse box there is no female plugs in there to accept the relay. my 3rd brake light has not worked since i got it. any info on this issue?
second question: not sure if anyone has had this happen to them. BUT, sometimes when i go to shift after hitting the brakes and comming to a stop. my abs light and emergency light pop on for a couple seconds then go off as if nothing happened, and there is no codes at all. and sorry if i asked this question before because i cant remember for crap lately.
Old Jan 6, 2009 | 01:32 PM
Numba1Sean's Avatar
Default RE: 3rd brake light question and other question.
figured out the first problem.
Old Jan 6, 2009 | 02:20 PM
The second problem/annoyance could be from a loose parking brake switch.
Old Jan 6, 2009 | 07:56 PM
Numba1Sean's Avatar
where abouts it that located?
Old Jan 6, 2009 | 08:14 PM
95Blzr's Avatar
95Blzr is an unknown quantity at this point
Could the light also be caused from low fluid in the reservoir?
Old Jan 7, 2009 | 08:18 AM
ORIGINAL: Numba1Sean
On the parking brake pedal assembly, next to your left foot when sitting in the driver seat.
ORIGINAL: 95Blzr
Yes, it could. However, I would have a good look at the brake pads front and rear. Unless you have a brake fluid leak, which I am sure you would know, the only other reason for a low brake fluid level is worn pads. If you fill the reservoir now and then end up replacing the pads, you can over flow the reservoir. A low reservoir is a sign that pads are getting low given a sealed system.
It could also be a momentary loss of WSS (wheel speed sensor) signal which could be caused by a dirty reluctor ring in the front wheel bearing assemblies. But check the parking brake pedal and brake pads / fluid reservoir first.
Old May 6, 2009 | 11:48 PM
jomin1016's Avatar
jomin1016 is on a distinguished road
So how'd ya figure out the first problem?
foanc
Dec 12, 2012 02:09 AM
dano440
May 11, 2012 06:57 PM
CraigSnedeker
Apr 27, 2012 07:47 AM
tripovermyego
Apr 12, 2012 04:09 PM
Numba1Sean
Oct 6, 2008 02:52 PM
