4.3 Oil Pan Questions...
Old Jul 10, 2009 | 04:32 PM
dew88's Avatar
dew88 is an unknown quantity at this point
Default 4.3 Oil Pan Questions...
I got my 4.3 out of my 4x4 s10 blazer and I got a 4.3 out of a 97 2wd truck.
My pan is 3" deeper and the drain is in the back, the new one is even with bellhousing and drains to the side. I am putting the new motor in should I transfer my pan over to the new block or will this one work?
Old Jul 10, 2009 | 07:30 PM
You should use your pan.
Old Jul 10, 2009 | 07:49 PM
dew88's Avatar
I thought that.
Is the diffrence in the 2 oil pans the diffrence between 2wd and 4wd. I kinda figured mine was built like it is to clear the front axle.
Thanks Swartlkk you have answered so many questions this week for me.
Old Jul 10, 2009 | 07:53 PM
No, it should not be the difference between 2wd and 4wd, but unless your transmission has the full round bell housing that would bolt up to the 97 pan (aluminum I assume), you really are not gaining anything other than an o-ring style seal.
I am not saying that it would not work, but you should measure it out first to make sure that it is not going to be a problem.
Old Jul 10, 2009 | 08:21 PM
dew88's Avatar
Ok you confused me but you know more obviously so I am gonna put my pan on. Thanks again.
P/S the back of each pan is identical but my pan has a bigger capacity, its deeper but the bolt up is the same
Old Jul 11, 2009 | 12:11 PM
Safest bet is to just use your pan.
I got to thinking about it and it should work either way, but without seeing the pans you are working with (96-97 was the transitional year for the pans so there were a few different ones), I really should not have made the comment I made above.
Old Jul 11, 2009 | 03:36 PM
dew88's Avatar
I went ahead and changed my pan and my oil pump to the new block. I done some looking and that other pan would not have cleared the fron diff. It come down at a angle where as mine is a L.
Putting the flywheel on first thing in the am and then dropping the motor in. Been without my blazer since december and I am excited to get it going.
Bluebeastblazer57
Aug 11, 2012 11:05 PM
99blklt4wd
Dec 15, 2011 05:00 PM
LoLoS10Blazer87
May 28, 2006 09:11 PM
blazingsadle
Apr 10, 2006 05:50 PM
swartlkk
13
Dec 20, 2005 08:13 AM
