4 wheel drive is not working
Old Nov 29, 2016 | 12:02 AM
Nathan Brumitt's Avatar
Nathan Brumitt is on a distinguished road
Exclamation 4 wheel drive is not working
So I have 2001 chevy s10 blazer. Since I bought it the 4 wheel drive hasn't worked. I was able to put it 4 wheel drive and the transfer case would engage but the front tires wouldn't spin. Now I don't have the option to put it in 4 high or 4 low. Also my abs and e-brake come on and off randomly. Just need some pointers to help me get my 4 wheel drive to work and the lights to stop coming on
Old Nov 29, 2016 | 08:23 AM
okaussie's Avatar
okaussie is on a distinguished road
First, what is more important to you, the 4wd issue or the ABS E-brake issue??
Could be separate but equal issues..
I, too issues with my 4wd not working and the ABS e-brake issue, however, in my case I know what is wrong and will be repairing one of the issues soon..
So, what would you like to tackle first??
Old Nov 29, 2016 | 04:43 PM
I would like to get my 4 wheel drive fixed first
Old Nov 29, 2016 | 06:40 PM
okaussie's Avatar
What do you mean I don't have the option of 4 hi or 4 lo??
Do you have the three or 4 button on the dash??
Old Nov 29, 2016 | 11:45 PM
Yes I have the buttons on the dash but they are not lit up and when I push them nothing happens
Old Nov 30, 2016 | 08:10 AM
okaussie's Avatar
If you don't hear the encoder motor engage when switching from 2hi to any 4wd positions, and have no lights on the switches, sounds like no power or the TCCM is bad.
Do you have the 3 button, part time 4wd, or the 4 button AWD system??
Old Nov 30, 2016 | 10:58 PM
I have the 3 button option
Old Dec 1, 2016 | 10:41 AM
okaussie's Avatar
It could be your 3 button dash switch. If the lights are all out and when you switch from 2hi to 4hi and don't hear anything, then maybe your dash switch is bad.
Still could be the TCCM or not getting any power.
Have you checked your fuses??
Old Dec 1, 2016 | 12:44 PM
butch049's Avatar
butch049 is on a distinguished road
Replace switch cheap fix they have them at part stores then check vac lines under battery they might have come loose. I replaceds vac lines or they came unplugged mine did everything works great now try that
Old Dec 2, 2016 | 12:12 AM
I will give it a try thank you guys!
