4wd?
The 4wd works by engaging the transfer case in the proper range and engaging the front axle with a vacuum actuator. On the front axle the left driveshaft is always connected to the differential and the right driveshaft is engaged/disengaged, so your front driveshaft is always turning when you're moving. When in Auto the front axle is engaged and the transfer case is in 2WD mode, if it senses a speed difference between the front and rear axle it will briefly shift the transfer case in 4WD mode (up to several seconds if it still senses slippage). There's a clutch pack so it doesn't grind the transfer case in Auto mode. When you change the fluid you use the factory GM Autotrack fluid, there is no substitute.
Mikes1Addiction
01-12-2007 02:08 PM
