4wd
4wd
I just noticed that when I put the truck into 4wd...both the 2hi and 4hi or 2hi n 4lo light stay on...seems like the front axle locks when I Jack it up I feel the axle is engaged...and u can hear the encoder motor working...no flashing lights...and it has a year old ac delco vacuum switch...any other ideas
Please first check for codes as described here and report.
https://blazerforum.com/forum/tech-a...gnostics-7683/
"If the shift select buttons all blink one time and stop, and do not continue to blink, no fault codes are stored in the TCCM". Make sure the buttons blink one time and then stop if you report no codes stored.
Ignition off - jumper pin 13 - key on and watch. I'm guessing it is OK.
1. Check fuses. You can look at the following to help id all the fuses involved. ATC and Courtesy fuses
https://blazerforum.com/forum/2nd-ge...-blazer-89670/
2. Check for corrosion on the 12V terminals on the TCCM - this is common.
3. If OK, then I am guessing the TCCM is bad. No other reason for multiple status lights at the same time IMHO. See schematic in page 3 of the link above.
Hope this helps...
Hope this helps...
The thing is that the front axle locks along with the drive shaft..so the 4wd works but I have both lights on...weird...I'm going to take off the tccm harness n clean it...if the tccm was bad I wouldn't have 4wd correct? Would the 4wd indicator switch be bad located at the front axle?
