4wd Operation ?
Old Nov 4, 2015 | 09:49 AM
LannyL81's Avatar
Default 4wd Operation ?
Couple of questions on details of the S10 Blazer 4wd operation:
1. When in 2HI, is the front differential turning?
I know the right front axle is dis-engaged from the front diff and the T-case is also not engaged.
2. If the answer to 1. above is yes, then is the front driveshaft rotating when in 2wd?
Just want to make sure I have the correct understanding of operation.
Thanks
Old Nov 4, 2015 | 12:10 PM
For "shift on the fly" to work, the front driveshaft must be rotating. If it's not rotating when you perform a mode shift, (2HI to 4HI, or 4HI to 2HI) there would be some nasty grinding going on during the shift . In 2HI, the differential powers the driveshaft. In 4HI, the transfer case powers the shaft. In both cases, the driveshaft rotates at the correct RPM to allow a mode shift without grinding.
Old Nov 6, 2015 | 09:29 AM
LannyL81's Avatar
Thank you once again Captain!
I just wanted to double check that I had the correct operation understanding....was doubting myself....
kevinph
Dec 20, 2010 04:58 PM
Bajimer
Nov 16, 2009 10:30 AM
starcruiser
Oct 17, 2009 10:52 AM
Sunshine Coaster
Sep 11, 2008 12:47 PM
CLSC1964
Dec 11, 2006 11:37 PM
