4WD partial operation issue
Old Nov 15, 2009 | 12:45 PM
Bajimer's Avatar
Bajimer is on a distinguished road
Unhappy 4WD partial operation issue
I have a 2000 Blazer (s10), 4.3l with the 3-button 4WD button. When I push the 4HI button in Drive, at any speed, nothing happens at all. When it's in Neutral, it will flash the 4HI/4LO lights. It will switch into 4LO properly, but when I try to go to 4HI, it just flashes and returns to 2WD. The 4LO is working, I tried it out in a field.
I was wondering if this would be a vacuum issue, or could it be a problem with the switch/control module?
Any assistance would be greatly appreciated!
Old Nov 15, 2009 | 04:27 PM
Check out this thread to check the codes:
OBD2 Non-Automatic Transfer Case Diagnostics by lastcoupe & swartlkk
Let us know what you come up with.
The Tech Article (DIY) section contains a few different posts about the NV233 transfer case that is in your truck.
Old Nov 15, 2009 | 09:07 PM
old skool luvr's Avatar
i had the same issue with my '98 last year when i bought it (that's why i got it so cheap). mine has the same t-case as yours, not the "Auto 4WD".
everyone that i talked to (@ GM & my driveline guys) said it was the encoder motor on the t-case. expensive as hell (even when getting it @ cost from the dealer), so i said, "screw it! i'll get a whole parts truck for that price!" i searched for 3 months-during the Winter when you want 4WD the most-found a truck, but by the time i stripped the parts truck, my 4WD started working, and hasn't given me any issues since. the only thing i did was pull apart the dash to replace the factory deck (CD wasn't working), and i think the switch must have been the issue, 'cause it's the only thing i touched related to 4WD in the truck. knock on wood that it'll stay that way, now that Winter is upon us again.
FML, i think i just jinxed myself with that comment! hahahaha
so check your switch, since it's the easiest thing to check (IMO).
Old Nov 16, 2009 | 09:46 AM
Bajimer's Avatar
Actually I think that I might have found it. I was checking the Actuator under that battery, and I sprayed the cable with WD40. I was then looking at the wiring under the vehicle, and discovered that a zip tie had come loose and allowed some wires to rub on the axle. The insulation was gone, so I cleaned them up, and wrapped in electric tape. Whatever I did, it works now!
Thanks for all the help!
Old Nov 16, 2009 | 10:30 AM
Good deal!
kevinph
Dec 20, 2010 04:58 PM
sprkz
Oct 8, 2010 09:35 PM
Qumodo
Mar 16, 2010 05:32 PM
psycoreefer
Oct 8, 2007 11:25 PM
CLSC1964
Dec 11, 2006 11:37 PM
