4x4 Center Link
Old Jul 20, 2011 | 01:08 PM
WickedBlazer's Avatar
WickedBlazer is on a distinguished road
Default 4x4 Center Link
Got a question on the center link for 98 S10 Blazer 4x4; is it the same bar/link as a 2wd?
Old Jul 20, 2011 | 01:15 PM
No. It is different between the two. The 2wd centerline has the outer tie-rods mounting inboard of the idler & pitman arm mounting points while the 4wd has them outboard.
Here are some illustrations that will help -->
2wd Steering - Compnine.com
4wd Steering - Compnine.com
Old Jul 20, 2011 | 01:22 PM
Got it. Would it be safe to say then that the need to replace a center link for a 4x4 is minimal. I have been advised to change the pitman and idler arm but was wondering if changing the center link would also be wise.
Old Jul 22, 2011 | 04:19 PM
step66's Avatar
Dependant upon the mileage of the unit in question:this is a GOOD idea-The reason is that once you pull the tires and the centerlink-you have immediate access to both!
Do It!
WickedBlazer
Jul 20, 2011 01:18 PM
MDE8
Dec 4, 2010 05:45 PM
monti72
Jun 19, 2010 05:06 AM
Marcin
May 11, 2009 12:43 PM
ChrisAttebery
Sep 24, 2007 07:20 PM
