4x4 does not work
Old Jul 31, 2007 | 10:52 PM
carlo's Avatar
carlo is an unknown quantity at this point
Default 4x4 does not work
I have a 95 blazer and i noticed that wen i put it into the 4x4 only the rear wheels are spinning and not the front. The light goes on when i press it saying that it is in 4x4 but wheni got stuck in the snow in the winter only my rear tires were spinning and not the front. Does anyone know the problem? Thanks in advance.
Old Aug 1, 2007 | 08:14 AM
Default RE: 4x4 does not work
You'll need to verify that your front axle is engaging. You have a vacuum actuator that engages the front axle in 4hi & 4lo. It is supplied with vacuum through the transfercase vacuum switch. If anything has happened to the supply to the transfercase switch or to the line from there to the front axle actuator, it won't engage. The same is true if the diaphram on the actuator has gone bad as well as if the cable has seized in the jacket.
Old Aug 1, 2007 | 10:05 AM
carlo's Avatar
so if i replace the vacuum actuator, the shift cable, and the transfer case vacuum switch should it work?
Old Aug 1, 2007 | 11:01 AM
Don't replace anything until you have checked out the various components. It could be something as simple as a faulty or disconnected vacuum line costing you practically nothing to repair. If, when in 4hi and engine running, you pull the vacuum line off at the front axle actuator (under the battery tray), you have good strong vacuum, then the switch and vacuum lines are working, but the actuator and/or shift cable are not.
If you do not have vacuum, then you either have a vacuum supply problem to the switch on the transfer case or a faulty switch. If your modes still work in your HVAC system, then you mostlikely have a faulty switch or a faulty line between the switch and the actuator.
TrainChaser22
Dec 4, 2019 12:27 PM
Flyfishen
Sep 19, 2016 11:07 AM
Amelia23
Sep 29, 2012 05:31 PM
underpowered
Nov 22, 2010 10:43 PM
