4x4 encoder failure?
Old Jun 13, 2010 | 04:55 PM
gantho's Avatar
gantho is on a distinguished road
Default 4x4 encoder failure?
So i have been having problems with my 4wd and today i finally got time to test some things.
- The transfer case will only shift from 2hi to 4lo. I have read on the forum that this is called an encoder failure.
- on my blazer (2000) it says to test the system you need to connect pin 13 to a ground source and turn the ignition on. I know the connector is under the driver side dash, but which one is pin 13?
-thanks, Tom
Old Jun 13, 2010 | 05:18 PM
gantho's Avatar
so i figured out the testing process and it threw a #2 code. i checked the connections at the transfer case and they looked fine.
So i guess i need a new encoder motor, is there a how-to on the forum for that process?
Helter80
Dec 23, 2024 10:04 AM
coolen
15
Jun 11, 2019 05:32 AM
Fred Nutcase
Jun 30, 2014 11:09 AM
BlackBastard
Dec 9, 2013 08:36 AM
Torqued
Aug 31, 2012 11:36 PM
