Is there a relay for 4X4? Also bad TCCM or encoder motor
Old Mar 19, 2013 | 10:34 AM
Helter80's Avatar
Helter80 is an unknown quantity at this point
Default Is there a relay for 4X4? Also bad TCCM or encoder motor
Is there a relay for the 4 wheel drive? I have a 2004 4X4 Blazer. I know there a fuse in the fuse box inside the engine compartment, but was wondering if a relay somewhere too?
I noticed when i pulled the 4x4 fuse out of the engine compartment fuse box, the fuse is NOT blown, but the pins that hold it in place look burnt/discolored.
I think I have either a bad encoder motor or TCCM. My problem is it gets stuck in 4HI if I switch it in & out of 2HI to 4HI a few times, or it will then get stuck in 2HI. the lights on the switch stay on, just nothing happens when I press the buttons. It goes in and out of 4LO with no problem.
*The only way to make it work again when it gets stuck is to disconnect and re-connect the battery.
Old Mar 19, 2013 | 12:11 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
After it gets stuck, do you hear clicking coming from under the dash after it gets stuck in 4wd when you try switching back to 2wd?
Old Mar 19, 2013 | 04:01 PM
Helter80's Avatar
Nope, nothing. The light is still on which shows which mode its stuck in, ex: 2HI, or 2LO, but nothing happens when I press the buttons. No clicking noise, and the lights do not light up for the other buttons. Just the light remains on for the mode it is stuck in.
Once I disconnect the battery and re-connect it, then it works again and I can get it out of 4HI, or 2HI, whichever one it is stuck in.
Old Mar 19, 2013 | 04:47 PM
Twip's Avatar
try looking this over. i dont know if you have seen this or not, but it might help some where.
4x4 no worky
Old Dec 17, 2024 | 04:09 PM
blazerbright's Avatar
blazerbright is on a distinguished road
My 1999 Blazer keeps clicking and the 4WD switch lights blink on and off but sometimes it settles down to normal and behaves properly. With my Blazer vehicle I really don't ever use the 4WD and 2WD is all I need. I just pulled the fuse for ATC and now no lights are lit on the 4WD switch and as far as I know I am just in 2WD which is ok with me. Can I just keep driving with the ATC fuse pulled? No check engine light lit up or Service 4WD did not light up either. Any suggestions?
Old Dec 20, 2024 | 09:11 AM
LesMyer's Avatar
I think you are just fine with the ATC fuse pulled, unless you need 4WD.
Old Dec 23, 2024 | 10:04 AM
Cyphercrash's Avatar
Cyphercrash is on a distinguished road
In my 1996 there a relay in the glovie
Zweber450
Feb 13, 2018 07:25 PM
skidud
Feb 9, 2014 05:46 PM
Helter80
Nov 15, 2013 05:17 PM
Helter80
Nov 14, 2013 06:15 PM
millernet
Aug 19, 2010 08:48 PM
