4x4 help
Old Jan 27, 2020 | 06:18 PM
Rolltide37's Avatar
Rolltide37 is on a distinguished road
Default 4x4 help
4 x4
When I have it locked in it wants to pull to passenger side and the lots barely light up on the switch on the dashboard
Old Jan 28, 2020 | 07:49 AM
LannyL81's Avatar
Suggest pulling the switch out of dash, carefully separate the halves, reflow the connector solder joints....or actually all of them on the board. See if this helps the lites.
Also check the TCCM connector for corrosion. Behind trim panel on right side footwell.
Now as far as pulling to the right; do remember that 4wd is not really 4wd; both diffs are open style, not posi. Check to make sure the left axle is fully engaged into the diff, not popped-out.
tapia auto
Aug 29, 2015 11:07 AM
ManduleyBlazer00
Sep 1, 2014 08:50 AM
walken1414
Feb 5, 2009 10:03 AM
peev0021
Jan 13, 2009 08:10 PM
rebelchevy
Jul 31, 2008 10:58 PM
