4x4, my turn now
Old Feb 7, 2014 | 07:14 PM
bizzs's Avatar
bizzs is on a distinguished road
Default 4x4, my turn now
I have a 95 blazer and I found out today that the 4 wheel drive is not locking in. There are no blinking lights on the switch and no codes detected on my GM tech 1. When I activated the 4x4 high and low, the front drive shaft will not spin by hand like its engaged. When in 2 wheel drive, the drive shaft will spin freely by hand. When I am stuck in the snow, the front wheels appear not to be locked in, or grabbing traction. Just the back wheel are spinning. Any suggestions? The vacuum hoses look ok, and the transfer case seems to be making that clicking engaging noise when I push the 4x4 buttons.
Thanks
bizzs
Old Feb 7, 2014 | 09:58 PM
Your transfer case is engaging. Under the battery tray is a vacuum actuator that engages the right front axle with the differential. When vacuum is applied to the actuator, the front differential is powered for 4WD. There is one vacuum line attached to the actuator. Engine at idle, trans in park, 4WD selected: The vacuum line must have manifold vacuum. Post your results.
blazen_red_4x4
Dec 30, 2015 04:28 PM
phrogchief46
Aug 31, 2012 07:41 PM
Blazinflaboy
Jun 22, 2010 09:03 PM
broke33
May 1, 2007 10:45 PM
shaka1111
Feb 13, 2006 02:23 PM
