4x4 not working
Special stuff and GM probably doesn't want to give up the secret to it.
NV233 & NV236 both look similar to the image. It shows the rear of the transfer case.
For the rear differential, 3 quarts will be close, little bit left over.
For the encoder motor to perform a mode shift, (at any speed) both drive shafts must be rotating at the same RPM. If all 4 tires are not the same circumference, the drive shafts will not rotate at the same RPM. When the vehicle is stopped, both shafts are rotating at the same RPM, zero
![Wink](https://blazerforum.com/forum/images/smilies/wink.gif)
mjw1991
02-24-2013 10:18 PM
blazer9893
06-07-2011 04:21 PM
bootlegger
12-14-2010 05:18 PM
218persuader
08-20-2010 06:11 PM
