4x4 problem please help!
Old Dec 4, 2012 | 08:56 PM
jhug1994's Avatar
jhug1994 is an unknown quantity at this point
Default 4x4 problem please help!
Hi i have a 1998 Blazer ls model i have been working on my 4x4 for the last week press 4hi or 4llo and it just clicked reset battery it just flashes then goes back to 2hi. I pulled computer out of kick panel cleaned prongs and put dielectric grease did nothing but flash then back to 2hi. So i took battery tray out diaphragm was sucked in all the time. Changed vacum switch electrical and the vacuum one press 4hi or 4lo flashes then back to 2hi idk what to do now its very aggravating! Please help me!
Old Dec 4, 2012 | 09:54 PM
4x4blazerguy's Avatar
Have you trased out your vacuum lines to be sure they are not switched?
Old Dec 5, 2012 | 06:08 AM
jhug1994's Avatar
No I have not I don't know which ones go where
Old Dec 5, 2012 | 12:29 PM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
Have you checked your t-case vacuum switch? The one in my 04 was borked into the 4wd position leaving the front axle locked up all the time and broke the shaft in the stub tube. This is not as common as having it break in 2wd mode.
Old Dec 5, 2012 | 12:58 PM
jhug1994's Avatar
Yes I changed the vacuum switch on the t case and did nothing the 4ho or 4lo just flashes and never engages
Old Dec 5, 2012 | 02:09 PM
aa21830's Avatar
aa21830 is on a distinguished road
Odds are pretty strong that it's your t-case encoder (shift) motor. To know for sure, there is a diagnostic procedure you can do that is fairly simple, which identifies the trouble codes that are stored in the TCCM. Take a look in the 4x4 article in the DIY section, starting with thread #5.
Old Dec 5, 2012 | 09:15 PM
jhug1994's Avatar
If that is broke and I have to replace about how much does that cost
Old Dec 8, 2012 | 06:35 PM
kenlani's Avatar
kenlani is on a distinguished road
try pulling fuse 13(I believe) lettin it sit then replace --this resets something , either the pushbutton set or the encoder not sure but it sometimes worked for me
Old Dec 8, 2012 | 11:17 PM
aa21830's Avatar
This will reset the TCCM (clears out the trouble codes). As for the cost of the encode motor, look here.
Recon
33
Jan 7, 2012 11:23 PM
Dhg1147
Oct 27, 2010 05:43 PM
rogggg1020
Nov 11, 2008 08:05 AM
gtmci84s
Nov 2, 2008 09:42 PM
1996blazer
Dec 6, 2006 09:34 PM
