4x4 switch is acting weird
Old Dec 20, 2005 | 08:50 PM
bfluke3's Avatar
bfluke3 is an unknown quantity at this point
Default 4x4 switch is acting weird
I HAVE A 99 BLAZER 4 DR
MY SERVICE 4 WHEEL DRIVE LIGHT CAME ON AND I REPLACED THE 4X4 SWITCH AND THEN THEY SAID THE CONTROL MODULUE WAS BAD SO I REPLACED THAT AND STILL THE SERVICE 4 WHEEL DRIVE LIGHT COMES ON BUT NOT RIGHT AWAY AFTER 5 MINS WHEN STARTED. WHEN ENGAGEING 4 WHEEL DRIVE IT WORKS WERID I PUSH AUTO 4 WHEEL IT GOES TO 4 HI AND I PUSH 4 HI IT GOES TO 2HI I PUSH 2 HI IT GOES TO 4 LOW AND VICE VERSA. I CAN GET IT IN AND OUT OF 4 WHEEL DRIVE BUT HAVE TO PUSH THE WRONG BUTTONS. SOMETIMES IT WORKS RIGHT BUT NOT LATELY. I HAVE NOT BEEN ABLE TO GET IT IN AUTO IN A FEW DAYS BUT HAD IT IN AUTO FOR A WEEK OPR SO AND WORKED FINE TOO. HELP
Old Feb 1, 2006 | 10:12 PM
my350tpi's Avatar
my350tpi is an unknown quantity at this point
Default RE: 4x4 switch is acting weird
Hi! I've got a 2000 and it's doing a very similar thing. Have you gotten a resolution to your problem? Please let me know - this is driving me nuts!!!!!!! Thanks! Paul my350tpi@yahoo.com
Old Feb 1, 2006 | 11:23 PM
4lowlife's Avatar
Hi guys, It could be the transfer case shift motor, a vacuum leak, or most likely the TCCM (transfer case control module.) It is located by the pass side kick panel. 3 10mm nuts hold it on the side. 2 harnesses plug in it. I had the same problem a few months ago.
I bought 2 (not at a time, they're $369.00 a piece!) from an auto parts store that in turn gets them fom a recycler. Both that where sent to me did not work. (for I have autotrak II.) I ended up buying a new one at the dealer. for about $30.00 more. It worked right away.
P.S. do not ever activate the shift motor when removed from the t case. it will permanately destroy it.
SuDu1997
Nov 8, 2013 01:42 PM
zedartwo
Jan 13, 2011 10:23 PM
99 Blazer 4x4
Sep 8, 2007 10:34 PM
91BlazerFrfghtr
Jun 12, 2007 06:49 PM
blazermanxx
Nov 22, 2006 01:00 AM
