55mph and loss of power
Old Dec 27, 2011 | 06:26 PM
Chevy33's Avatar
Chevy33 is on a distinguished road
Default 55mph and loss of power
95 GMC Jimmy 4x4
Tonight while driving home I went to use the high-beam and the power went out. I was traveling 55mph. The lights, radio, motor; everything was dead. The road was not lit with street lamps so I had to slow. When I hit the brakes, everything came back to life. This is the first time I've experienced this. Any ideas?
Old Dec 27, 2011 | 06:32 PM
Sounds like the high beams maxed out alternator output or possibly a short in the headlight circuit that maxed out alternator output, causing a drop in system voltage. It's weird that it all came back after pressing on the brakes...
Can you reproduce the problem?
Old Dec 27, 2011 | 06:35 PM
Chevy33's Avatar
I'll try to recreate on the weekend.
Why would it restore power when I stepped on the brake pedal?
Last edited by swartlkk; Dec 27, 2011 at 06:43 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Dec 27, 2011 | 06:41 PM
Did the engine actually stall out?
As far as what would make it all come back after pressing the brake pedal... That's a mystery... I can't recall seeing symptoms like that before.
Old Dec 27, 2011 | 09:34 PM
Any chance there's an aftermarket security system installed, or a remote starter?
Old Dec 27, 2011 | 11:24 PM
David Hineline's Avatar
David Hineline is an unknown quantity at this point
I would first check the status of your battery cables.
Old Dec 28, 2011 | 07:44 PM
Chevy33's Avatar
Default Same thing again
I was driving home again tonight and against better judgment I hit the high beams again. Same thing happens. The engine died and all power was lost. I hit the brake pedal and everything came back on. I hit the high beams a second time and everything stayed on. I turned the high beams on and off several times and everything stayed on. I was driving for about 5 miles both nights before turning on the high beams.
bam_9_9_9
May 25, 2014 01:34 AM
bryanmine
May 19, 2011 11:27 AM
tersus
Feb 25, 2009 03:26 PM
kerander
Jan 18, 2007 01:21 PM
blazzinblazer1998
Feb 16, 2005 04:41 AM
