6" vacuum hose was on my garage floor
Old Jan 2, 2016 | 12:10 PM
mattjphoto's Avatar
mattjphoto is on a distinguished road
Default 6" vacuum hose was on my garage floor
I thought it would connect into the fender for the vacuum ball but all those hoses are there. Any ideas where this little guy goes?
2002 Blazer LS
https://flic.kr/p/CjbbGq
Old Jan 2, 2016 | 12:37 PM
newguy's Avatar
If your not losing any vacuum it may just be a vent hose off the front tranaxle, or transfer case
Old Jan 2, 2016 | 12:54 PM
mattjphoto's Avatar
Thanks I'll take a look. I'm changing my oil right now and figured while it was draining I would change out the rotor to try and stop my misfire. Is there suppose to be this much play in the rotor? I've change the plugs, cap and rotor with in the past couple of weeks. Also the injectors were changed too.
https://flic.kr/p/BNYcpi
Old Jan 2, 2016 | 02:14 PM
newguy's Avatar
hmm not sure, anyone else? chime in
Old Jan 2, 2016 | 07:50 PM
Red Sled's Avatar
Red Sled is on a distinguished road
Yes its got that much play. # 5 plugs is Toast?????? Why new plug on # ! That hose looks like its under hood. Check all hoses from intake manifold to check valve forward. .02
Old Jan 2, 2016 | 08:21 PM
mattjphoto's Avatar
Thanks Sled for the info and tomorrow I'll see if I can find where it goes. I've replaced injectors, all 6 plugs and wires, distributor cap and rotor trying to figure out why I get a misfire code going up hills. I made sure my cam retard was at 0. Cleaned my MAF sensor when I was changing oil and air filter. Compression check was good but my fuel pressure was off by a couple psi so I changed the fuel filter for ****s and giggles by didn't help. I really doubt the fuel filter is the main problem b/c the light only comes on going up hill.
OILCOUNTRY
Apr 5, 2011 08:20 PM
trailblazer01
Mar 7, 2011 12:26 PM
midnightmekanik
Oct 8, 2009 08:32 PM
Sisk
25
Aug 30, 2009 07:47 AM
drperry
Sep 18, 2007 07:01 PM
