6K winch enough
Old Nov 1, 2013 | 03:39 PM
ckroll98's Avatar
ckroll98 is on a distinguished road
Default 6K winch enough
Is a 6K winch enough for our trucks? 2dr 4x4 with just a few mods.
Getting a good deal on a 6K winch and brush guard.
Old Nov 1, 2013 | 04:12 PM
rexmburns's Avatar
Super Moderator
The rule of thumb is that you usually want a winch rated for twice the weight of your truck. I have seen 1 or 2 others that have ran a 6k but no word on how they worked. I would say learn how to properly use it with a ****** block to double the the pull strength an it should work ok it will just be reallllllyyyy slow
Old Nov 1, 2013 | 04:15 PM
ckroll98's Avatar
Yeah, I was gonna use a ****** block. I've seen Dirty Jobs do a special on Military, and the soldiers pulled a stuck Hummer out of the mud with several ****** blocks and just a couple guys pulling on the cable. That sold me on them, but yes, very slow.
Old Nov 1, 2013 | 06:36 PM
abig84's Avatar
better then nothing especially when you are stuck alone. theres been a few times my 9000lb winch wouldnt pull out my 6000lb suburban on 38s when buried in mud. i would usually have to bust out the highlift jack, jack the truck up throw whatever i could under the tires and then try again.
so the 6k should be better then nothing
Old Nov 1, 2013 | 06:40 PM
newguy's Avatar
I believe I read somewhere the formula is 1.5 times the weight of your truck
Old Nov 1, 2013 | 10:27 PM
Clancy Pell's Avatar
Clancy Pell is on a distinguished road
In MHO, a 6000lb winch would be only adequate, for most situations of self recovery. Most of the time you will require a ****** block. This limits your pulling distance to about 1/2 of the winch line capacity. It would be in your best interest to carry about 150ft of straw line as a backup, along with a couple of 3/4 inch shackles and a 20ft tree saver strap. Don't be concerned with the slowness, It just gives you adequate time to spot a hang up before you tear something off.
Old Nov 2, 2013 | 05:33 PM
cleburne red's Avatar
This is what I've heard. A 6k would work, I guess. It would be pretty slow, but I'll take a slow recovery over no recovery! if the deal is good enough, I would go for it.
Old Nov 2, 2013 | 09:00 PM
rexmburns's Avatar
Super Moderator
Now thy you've said that your right! I was thinking a little high lol and not the "high" that just came to your mind either
Old Nov 3, 2013 | 03:02 AM
newguy's Avatar
Never hurts to have a little extra, And not the little extra your thinking about. LOL
Old Nov 4, 2013 | 01:47 PM
Diaita's Avatar
Will it work, absolutely! Usually when you're stock, all it takes is a small amount of pulling force...2000 lbs say. Keep a ****** block or two with you and you'll be set.
I have a 9000# on my 3500# Jeep and I have stalled it out on several occasions.
newguy
Jan 4, 2014 05:26 AM
Sturg
Feb 10, 2011 02:31 AM
old skool luvr
Jan 31, 2011 08:26 PM
Shalom
Jul 21, 2010 11:31 PM
bcg187
Jul 28, 2005 12:52 AM
